Arris DCT700 DTV Receiver Logo
A
Anonymous Posted on Jan 02, 2012
How do you disable the DCT700 parental controls
I got a new DCT700 from shaw cable with the locks on without my knowledge. I have no info for disabling preset locks
Anonymous232
Level 3:
Genius:
  • Arris Master 1,552 Answers
  • Posted on Mar 02, 2015
Anonymous232
Arris Master
Level 3:
Genius:
Answers
1552
Questions
Helped
270299
Points
2945
If it is "new", then take it back to Shaw, and exchange it.
Can you get a parental code off an xbox
Here is the procedure to reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
4helpful
I just got a new TV (42 LG LCD), and i was using a 42Panasonic. well since switching TV's my shaw receiver (DCT700) is not working properly. it will work for a couple mins then it stops working and the...
Hi, i wastrying to research about this issue, and yesterday i did all test possible tofix it. I have 2 of these boxes in different TV's and only in one TV is working(32") but in the 42" TV (LG) I'm having exactly same issue.Incredible but by disabling the Energy Saving mode in LG TV the DCT700 worksnormally immediately I activate the ES remote stop working. Try it and let meknow if you resolve this frustrating problem!
I bought a ps2 for my son, but it is locked ? I want the step by step procedures for it ? I read few articles, it says that, if you disable parental control the whole ps2 is unlocked ? is it right ? pl....
do you know the code?
if not, do the following in this order:
press 'select' button-->enter 7444-->enter new code-->re-enter new code-->scroll down to select parental control level or select 'off ' to disable it.
hope this helps :D
3helpful
2answers
Parental contolled locked. I bought a used xbox and I need to reset the parental controls to play video games.
GA_googleFillSlot("TL-IMU-Article"); reset the parental lock code:
Thanks Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
How to unblock parental control regular xbox
1helpful
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
30helpful
2answers
Cant remember parental control code.
All Details Below On How To.
Turn off your 360 Unit
Remove all memory devices
restart 360 Unit
go to system blade > Console Settings > System Info
press
left trigger, right trigger, x, y, left bumper, right bumper, up, left bumper, left bumper, x.
This should bring up a menu
Reset System Settings
Resetting your system settings
will return all console settings to
factory defaults. Do you want to
reset to factory defaults?
Yes, reset settings
No, don't reset settings
select to reset settings
your screen should go blank for about 2 seconds
then the language blade should appear that lists several different languages,
select your preferred language
then a blade that says "Xbox 360 Storage Device" should appear
With the options of,
Done
Continue without one
select to Continue without a profile
Then an Initial Setup Complete screen should appear
with the options of,
Family Settings
High Definition Settings
Xbox Dashboard
select Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on.
No more Parental Control lock.
Parental control
fixya!
Top Arris Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
