I have only had the phone for a few days. I was charging my LG Enlighten and I saw it go off. I tried turning it back on but it wouldn't. After taking out the battery and putting it back I tried turning it back on again. The LG screen shows but then goes black, presumably it is off again. Why is this happening?
SOURCE: Won't Turn On/Charge
hi , i know a friend have one like that, same probleme he have to bring back to make it fix by the compagny,, only help can give you Yvon chow !!!
SOURCE: My LG VU CU920 keeps turning off
I had the same problem even after I exchanged the phone for a new one. The problem seems to be related to Mobile TV and the SD memory. When I removed my 2GB SD memory, the problem has not reoccurred. I recently installed a 512MB SD memory chip and so far I have not experienced the problem.
SOURCE: lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
I took out the battery on a lg verizon phone oops put it back in now black nothing ?? There must be some sort of way to replace the battery that reinitializes it any help
SOURCE: my LG lotus won't turn on.
Mine started doing the same thing yesterday. In doing a bit of research I found on the LG support forums that the phone is probably fried. The good news is that it's covered under the 1 year manufacturers warrenty and can be returned to the sprint store, or your carrier and they will replace it on site. I've already talked to Sprint and they said as long as there's no water damage or other visable signs of shock that would have caused the damage that they'll provide me with a new phone. This was a huge relief to me, I loved this phone before it went batty and really can't afford a new one.
Hope it works out for you as well.
SOURCE: how do i resolve the error: use genuine battery. power off
A temporary fix to the problem is to put the battery in the freezer for a minute and then put it back in the phone and it will turn on just fine! I had an LGVX8700 and it just randomly started happening one day and my fiance told me to try doing that so i did and sure enough it worked. I had to go to verizon at one point to get a new phone because the one i had got damaged and the tech there used the same battery in my phone for the new one and he thought i was crazy when i told him to put the battery in the freezer but he was in for a surprise when he did what i told him and my phone turned on. It's annoying because you have to do that everytime your phone shuts off but i always made sure i plugged it into the charger before it went completely dead.
