Error message: BM init error
SOURCE: JANOME MEMORY CRAFT 8000 MANUAL
tighten the thread TENSION CONTOL.
Loose adjustment causes your problem.
if its possible for you to send me a large front picture of your machine then i guess i could give you more info. my email : jyzomnix1Yahoo.com
SOURCE: Janome Memory Craft 7000 Sewing
My Memory Craft 7000 sometimes does the same thing, if it's very cold. Try warming it up by placing it near a heat source, a vent or a floor heater, for a few minutes. Then it works perfectly.
I've used these machines for over 20 years now, and they're my favorite!
If this doesn't solve your problem, you need to take it in for servicing.
They are work horses, but they do need their maintenance from time to time.
I hope this helps you.
SOURCE: JANOME MEMORY CRAFT 5700 INSTRUCTION BOOK
Hi, I downloaded (for free) a copy of the Envision 8006 (and 8007 supplement) manual from the Elna website 2 1/2 years ago. The Envision 8007 is the same as the Janome Memory Craft 5700. I can email you a copy of the manual.
SOURCE: WHERE IS THE FUSE FOR THE JANOME MEMORY CRAFT
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the bottom to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
SOURCE: I have lost the manuals to my janome memory craft
To get your FREE MANUAL follow these instructions:
Go to Janome.com
Select USA as your country
Go to "Machines"
Select "Retired"
Select "Memory Craft 10000" from the list
Click on "Specifications"
On the top right hand corner click on "Download Manual"
A PDF file containing the manual will then be downloaded into your computer.
Job done!
Thanks for nothing.........
