SOURCE: need help bigtime
Here Mouthy22 the diagram:
If you need a manual for your MOBO just click HERE..
Enjoy!
Thanks,
are those all seperate connectors for the button? Or are they all together on one block? Should be something near bottom right hand corner of mobo saying pwr, hdd, sw, snd, led, that kind of thing
SOURCE: TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are
mainly,
Harddisk activity connector
This normally comes red in colour and is labeled
as HDD-LED
Power switch connector
This comes green in colour and is labeled as
POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled
as RST-SW
Power LED connector
This is usually green in colour and is labled as
PWR-LED
Speakers connector
This speaker will give different beep sounds
during boot to tell the user if there is any errors. It
occupies 4 pins, however only 2 is important for the
function. Be sure to connect the red coloured cable
to the positive polarity and the black to the
negative.
Front panel connectors pins on the
motherboard
Front panel connectors from the
casing
Good luck and thanks for using FixYa!!
SOURCE: hooking up replacement mobo 946 GZT-AM V:1.0. Need
HD LED is just a LED -- if you get it "backwards", either the lamp will light or it won't. No big deal.
PWR SW is a switch -- press the button to close the circuit,
and release the button to open the circuit. Polarity does not matter.
USB connectors have 9-pins: 4 in one row, and 5 in the other row.
So, look for a '1' on the motherboard, beside the first pin;
there is no 10th pin.
Did the motherboard *NOT* come with a reference manual?
Did you search on the Internet for the manual for "946 GZT-AM" ?
Testimonial: "good start"
SOURCE: Describe your 261983 001 motherboard Problem.
Here ya go Check the site and open the pdf file this is a service manual for EVO s310m
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&docIndexId=64255&prodTypeId=12454&prodSeriesId=385204&lang=en&cc=us
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If
this Answer goes some way towards helping to resolve your Query, Problem or
Fault, please take the time to Rate it. Doing so helps Solution Providers, like
me, better understand the needs and the point of view of Askers, like you, and
guides us in exploring the best ways to provide the most comprehensive, useful
and high quality Responses and Solutions we can. If you need further help,
please do not hesitate to post another Question or add a Comment to this
Question.
Thanks
for using FixYa.
