I turn on washer and stops working at fill and will not unlock untill afue minits later it leaves my close all wet tho
Hi.
The question has been posted in dishwasher. I understood that the problem is with a washer. Troubleshooting is similar in both appliances. Below the parts to test.
Check pressure from house, inlet valve, water pressure switch, door switch and electronic control. If this is a dishwasher check if there is residual water at the bottom of the tub on start-up. If this is a washing machine instead of a dishwasher check also the setting of the drain hose.
The user can run a diagnostic cycle and check in what part of the cycle the machine is stalling. The technician can test the parts mentioned above individually reading volts and impedance or jumping contacts.
Regards.
Ginko
