SOURCE: Where can I obtain a
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Hi
The issue is with the door lock assembly that is bad and
should be replaced. If the door lock assembly is bad the control will sense
that the door is open and so will not start a spin cycle. If you want you can
test the door lock assembly with a voltmeter before replacing it. Hope this
helps...please post back for further assistance.
Daniel
