Cable is connected and channels up to 119 can be found and played. An attempt to get 225 just brings a black screen. TV in family room receives, so cable is connected and works.
Depending on the brand, model and features (capacity/limitations) of each TV, some are not programmed to access certain channels over and above a certain point. Pls post back the brand and model of each of the TV units.
Alternately, you can try going into the MENU Setup and determine if you can perform a re-SCAN. In some instances, you may have to check the specific setting of the CABLE selection. There are several possible choices and largely dependent on what your cable provider is using; STD, IRC or HRC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
