i have ac panasonic cs-e21gkr so error code is F90 could you have me what problem with my airconditioneri have ac panasonic cs-e21gkr so error code is F90 could you have me what problem with my airconditioner
You can't post conmments that contain an email address.
Inspect foil side of HV board for burned tracks toward lower side of board. If burned, check HV capacitors (High Voltage Capacitor Test Procedure) and HV transformers (High Voltage Transformer Test) for a short. Otherwise test other components as outlined above. Solution: Replace defective components as necessary. If applicable, repair foil trace on HV board.
Hope that helps.........
? 2:17
https://www.youtube.com/watch?v=DZVaqMBmUpU
Aug 6, 2012 - Uploaded by PanasonicUK
Microwave Ovens: Panasonic in-house expert Janet introduces the main benefits of the Panasonic ...
Hi Wendy, The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on
CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me Thankyou Mat
hi my name is mark, that code stands for current sense.CS the following is a list of the possable things it could be. 1. interlock sw. 2.open thermal cut-out 3.open/loose wire 4.power relay 5.H.V. board 6.diode 7. magnetron 8.capacitor 9.transformer 10.triac it is worth fixing. RC22s are very expensive ovens if you need part #s i will need the serial # and P# [P132....M] to get correct parts. hope this helps. thaks for your question.
What is it doing or not doing?
