I have register the phones and the ringer is on high and th silent mode is off but the cordless phone will not ring but the wall phone doe,s.
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
I believe you can navigate through the menu and when you get to the ringer part push up on the navigation arrow. That should work. Thanks for using Fixya.Com.........Enjoy your evening!
SOURCE: change ringer from lo to hi
Do you know the model #? If so, you can get the owners manual from the the uniden website. Here is a link to the page so you can look for your specific model number. Just click on your model number and it will load the pdf format of the owners manual.
http://www.uniden.com/index/manuals_results.cfm?cat=1
SOURCE: I just have a question. We have a Uniden 5.8GHz
My phone is a Uniden TCX905 model.
Ringer Volume
Choose from three ringer volume settings (off,
low, and high). With the phone in standby(normal display), use button on center of handset. Press up arrow or down arrow to adjust the ringer volume.
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
SOURCE: how do you trn a uniden D1660 cordless phone off
To exit the silent mode, press and hold # on the handset for about 5 seconds. In the future, when you set the silent mode with this press and hold routine, you can follow it by a number (1-9) to set a specific length of time for the handset to be silent. Otherwise it will stay on until you manually turn it off.
The manual for the D1660 is available from http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf .
I hope this helps.
You can silence the ringers on the base and handsets at the same time. It doesn't affect the visual ringer on the phone in standby, press and hold Silent on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on handset. (The answering system answers any incoming calls without playing anything through the speaker.)To cancel, press Silent again. If you turn the answering system off while Silent Mode is on, the phone turns off Silent Mode.
