Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Oct 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi 1995 cs31205 32 inch tv
1st problem
the tv has a large black rectangle over picture
can hear and see picture around the outside of square
can touch input on tv the square will temperally disappear and then return
2nd problem
remote worked and i was pushing buttons to get the black rectangle to disappear now the remote will not work on tv at all
  • snappyron May 25, 2009
    The power went out momentarily and now we get a message about resetting the clock and encounter the big black square over the picture.
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Oct 10, 2008
Anonymous
Master
Level 3:
Answers
927
Questions
Helped
302474
Points
1655
Good Day;
Sounds like you have the TV in the "close caption " mode (text), turn off. 2. Check batteries and the mode the remote is in; eg TV, VCR, Cable & ect. Good Luck, big IRISH.
I get a large black rectangle covering 1/3 of my
I have a similar problem using an older 20" flat screen standard definition TV. (not High Def). I can see a little of the picture but more than 2/3 is covered by the black. My model is LC-20SH7U.
I used sharpusa.com "contact us" section.
Hopefully I get some kind of reply to report what they say.
Is closed caption turned on? (and the channel doesn't have any captions) Turn it off.
I have a mitsubishi vs 5059, when i open the TV I get a black square covering most of the tv but i can hear the sound and also see the picture outside of the black square. I don't know if there is an error...
You can likely buy a replacement remote here:
Remotes.com
'Universal' remotes exist only in your dreams; there is no such thing since the manufacturers cannot agree on a basic code set that would work with any set. None of them can control every function of every brand and model made.
2helpful
1helpful
2answers
How to fix TV
I have a large black square obscuring the picture. You can see the picture in 1 inch border around the black square. If I reset the input switch, the black square disappears for about one second (the picture is momentarily perfect) and the black square appears again. It is not the cable box because I wired the cable directly into the tv. The same thing happens when I try to play a DVD. Any insights????
4helpful
Black square on tv screen
Turn off your closed caption...
Bill
3helpful
Black squares or rectangles over picture
It's the closed captioning. The reason it doesn't go away when you press the "caption" button is because there are four option for closed captioning: Text 1, Text 2, Text 3, and Text 4. The fifth option, which has no designation, is the "off" option. Using the remote, just click on the "caption button until the option has no designation.
Mine was a large black rectangle in the middle of the picture. It's not like Nina3's problem.
2helpful
Black screen
I have a Sharp Tv that had the same problem with a large brownish or black square right in the middle of the screen. It only left about an inch around the edges that you
could see the picture moving in behind the big black block or square.I have DISH sat-elite and the book recomending that I check and see if the "caption settings" were on
or off. They were on. I turned the caption settings off and the large square diappeared.
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Black square in middle of TV
Turn off the closed caption on the TV set. Someone has turned on that feature. Good Luck
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
