It uses the HC26P filter. The solenoid is working, but the unit will not turn on. Theromstat is attached to the incoming airduct, brfore the furnance filter. The furnance os a Carrier.
Most of the humidifiers are run by 24 volts AC. disconnect the power wire to stat on circuit board and check there with meter and connect to low voltage ground for 24 volts, I'm assuming the two wires that power the humidistat are red and white.typically red is used for power. most likely you have power if the red for the stat is connected to the W on the board and the heat works, but the humidifier only works while heat is on.the next thing in line is the humidistat , it's a switch so if there is only two wires going to it take them off the stat and connect together, if furnace is on heat and running and stat wires are connected it will send power to water solenoid, if its not working yet the problem lies in the water solenoid if you have 24 volts at the two wires at solenoid.check while disconnected, do not connect those two wires together or a 3 amp fuse will blow on the furnace board. if you have 24 volts there then the valve may be bad or the valve may be stuck or clogged, loosen water supply line to make sure water is getting to valve. I spent many years working in the HVAC industry.
Testimonial: "Thank you Scott. I am going to look for the fuse. Found that the white wire connected to the thermostat has a small nick in it. Your info was very helpful."
Found the fuse. The wires look ok...no breakage, but the plastic is cracked. I am going to replace it.
