Bobbin case is not moving. View from the bottom shows the belt is in place but I can't see where it connects to that turning gear. Any ideas?
SOURCE: bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
SOURCE: bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
SOURCE: I own a Singer kitting machine (circa 1990) in
yes what do you need to know?? you will need to give it a good clean first i use surgical spirits, a good paint brush for flicking out dirt, a strong vacume cleaner, a coffe jar to put spirits in with the needles shake them about and they clean them selves.. dont forget to put a good sized piece of material down on the floor to protect your flooring as plenty dirty oily stuff will come out...lots of non fluffy cleaning rags, cotton is best... askmore details and i will help more thanks heidi
SOURCE: How to replace the bobbin case in a singer sewing
If you go here and search for 9005, you can find a free downloadable instruction manual.
http://www.singerco.com/accessories/manuals.html
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Singer zigzag model 457 ? Where is the bobbin gear powered?
