Microsoft Xbox 360 Console Logo
Posted on Oct 05, 2008
Xbox 360-computer? how do i connect my xbox 360 to my computer for the media part
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
218
Points
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Cannot connect xbox 360 to PC running vista
If you are just trying to share files from your PC to your 360 through Windows Media Center then you have activate the Windows Media Center Mode in your 360 settings and then use the code given and type it into your PC so that your PC shared files can be synced to your 360
Xbox set up
If you have an Xbox 360 connected to a home network that also has a Windows Media Center, you can add your Xbox 360 as a Media Center Extender device so that you can enjoy the digital media on your Windows Media Center computer by using Xbox 360. For more information, see Xbox 360 online.
1. Turn on your Windows Media Center computer and log on to Windows. Verify that your computer is connected to your home network.
2. Turn on your Xbox 360 and verify that it is connected to your home network.
3. In Windows Media Center, on the start screen, scroll to Tasks, and then click add extender.
4. On the Welcome to Windows Media Center Extender Setup screen in Windows Media Center, click Next.
5. Press the Green Start button blank.gif on your Xbox 360 remote control or use your Xbox 360 controller to select the media blade.
6. On your Xbox 360, select Media Center.
7. On your Xbox 360, follow the instructions on the screen to obtain an 8-digit Windows Media Center Setup Key. Write down this 8-digit setup key. This is the key that you will use to affiliate your Xbox 360 with your computer that has Windows Media Center.
You do not need to download any additional software because the Extender functionality is built into Windows Media Center.
8. On the Enter the Setup Key screen in Windows Media Center, use the Windows Media Center remote control or keyboard to enter the 8-digit setup key that displays on Xbox 360, and then click Next.
9. Follow the steps in Extender Setup.
Several changes are automatically made to your Windows Media Center computer during the Extender Setup, including changes to the Windows Firewall settings. For more information about Windows Firewall, see Windows Firewall: recommended links. During this time, the Windows Media Center Extender service (which is named mcx2svc) starts on your computer, along with other dependent services.
If you have a firewall running on your computer that is not the Windows Firewall, make sure that the firewall software is set up to allow Xbox 360 to connect to your Windows Media Center computer as a Windows Media Center Extender. Some firewalls are already set up to allow Xbox 360 to connect to a Windows Media Center computer as a Media Center Extender. However, other firewalls will require you to make changes to how the firewall software is set up. For more information about which firewalls are already set up to allow a Media Center Extender connection, as well as information about how to set up other firewalls to work with a Windows Media Center Extender such as Xbox 360, go to the Firewalls and Media Center Extender article on the Microsoft website.
10. After Extender Setup has finished, in Windows Media Center, click Finish.
On the TV that is connected to Xbox 360, the Windows Media Center user interface appears. You can then enjoy live TV, recorded TV, pictures, music, videos, and other digital media on your Xbox 360 as you would in Windows Media Center. A new user account named mcx1 (by default) is automatically created to use the Extender.
Please see http://windowshelp.microsoft.com/Windows/en-US/Help/8076aff3-16ec-4751-9f57-d36e0ff407201033.mspx#EPD for more info.
Thanks and hope that helps!
Les
How do i connect my 360 to the computer
I had this same problem and found this great video on youtube.
go here:
http://www.youtube.com/watch?v=BaKgCYkSCjc
over 175,000 views
if you click the drop down on the info you'll see the step by step instructions.
STEP 1
If you were previously using your Xbox 360 with a Windows XP Media Center Based PC, you will need to remove existing connection. Otherwise skip to step 2.
At the Windows XP Media Center PC
Click Start, point to All Programs, point to Accessories, point to Media Center, and then click Media Center Extender Manager.
Select your Xbox 360 and click Properties.
Click Remove.
Click Yes to confirm removal.
At the Xbox 360
On the Xbox 360, go to My Xbox and then System Settings, then select Computers.
Select Windows Media Center, and then press the A button.
Select Disconnect.
Press the B button until you return back to the System Settings.
STEP 2 Gather Setup Key from Xbox 360
Press the Media Center Start button on the remote or go to My Xbox, then select Windows Media Center.
Advance through the on-screen instructions to obtain the 8 digit Media Center Setup Key. Write this key down.
STEP 3 Add Extender
At the Windows Vista-based Media Center PC, launch Windows Media Center. Select Start, Windows Media Center.
Select Tasks, Add Extender.
When prompted, provide the 8 digit setup key you received at the Xbox 360.
Complete the Extender setup.
STEP 4 Print the Media Center Quick Reference Guide
How do i put songs on my xbox
Follow these steps :
1.
Burn CDs. The easiest way to put music on your Xbox 360 is to rip CDs from your own collection. Simply insert your favorite CD in you Xbox 360 and then pull up the secondary menu with the Xbox logo button. Then select "Rip CD" from the menu to transfer the tracks from the CD to your Xbox hard drive.
2.
Sync your computer with your Xbox 360. If you have Windows XP Media Edition or Windows Vista (any edition) and a wireless connection your computer will be able to detect your Xbox 360 and can share media with it. Simply find the "Windows Media Extension" tool on your PC and follow the prompts to stream video to your Xbox 360.
3helpful
3answers
I do not know how to connect xbox 360 to my vista laptop. i plugged in the Ethernet cable to both the laptop and xbox but it doesn't show the xbox 360 on the network connection after i've clicked ''manage...
Remember to thumbs up this solution if it helps, if not comment for further assistance.
Plug your xbox into the laptop with an ethernet cable
Turn on your xbox
On your laptop press start, click on network
In the blue bar across the top click network and sharing center
click on manage network connections
right click on local area connection
click properties
click sharing tab
untick top box.
Go on your my xbox page, scroll over to the right to the system settings page, network settings,test connection.
This works for me.
My xbox 360 cant get a valid ip adress from my router to ad an extender to share media with my pc.And my internet connection is fine.
You dont need an internet connection to add an extender, but also if you are doing the xbox live network test, make sure you turn on INTERNET CONNECTION SHARING otherwise you will not connect,run a pc - xbox , then media connection test, etc, also make sure you have the media centre open on your computer also. Good Luck.
Can't connect with network
if u dont hav e a router that is ur problem. to get ur xbox 360 to connect to vista media center you cannot connect an ethernet cord directly to ur 360, u must have ur computer hooked to a router with one ethernet cord and a whole different ethernet cord connecting to the same router the computers hooked up to. after you do that go to ur vista media center, turn active sharing on, make sure your router is connected to the internet. then go to ur xbox 360 and follow the on screen instruction from the the connect to media center screen.
if your wanting to connect to xbox live and stuff like that, and u enter ur ip address and security information and it tells u that the ip adress u entered is already in use by another device, and that ur xbox 360 needs to be assigned one, do this: simply go to were u put in ur ip address and set it to get the address automaticly (or in other words choose automatic). then go to test connection (ur router should automaticly assign ur xbox 360 an ip address) and ur router should connect to the internet. if it connects to the internet but not xbox live then u have not yet sign up for an xbox live account.
by the way when u make an xbox live account please send me a friend request. my xboxc live account name is: ghdude22
glad i could help!!! :3
2answers
I cannot link my xbox to the pc or window media centre.
go to microsofts download site. And get a program Called XBConnect. Or xbox connect.
Thankyou For Using Fixya.
Mike @ compurepair.
Media sharing WMP11 networking.
Your settings on your PC may not be set to allow sharing to your 360. The way I do it, is I download windows media player 11, imported my itunes library and my movies I had on my PC and allowed sharing via media player. These steps can be seen in more detail by going to www.xbox.com/pcsetup
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
