Canon DR9050C Logo
Sandy Moretti Posted on Dec 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DR9050C not removing blank pages - Canon DR9050C
Mohan Sriraman
Level 2:
  • Expert 490 Answers
  • Posted on Dec 31, 2014
Mohan Sriraman
Expert
Level 2:
Answers
490
Questions
0
Helped
247055
Points
823
The scanner/Computer decides 'Blank pages' as a percentage of area covered. By altering this figure you can select 'Blank pages' based on your paper noise/background. To put it simple, keep percentage low for clean background.
S. Mohan, India
How to remove blank page in word
Solution 1 :
Go to your unwanted blank page in your Word document, click at the bottom of the page and press your Backspace key until the page is removed.
Solution 2 :
Click the "View" tab from the Ribbon and select the "Navigation" Pane in the "Show" section. Now, click on "Pages", and select the blank page thumbnail in the left panel. Press "Delete" key.
Why is my printer is printing blank pages
Printer Printing blank page issue can be occurred when you have low or dried ink cartridge, blocked nozzles, dirty print head and ink cartridge installed improperly. Follow the troubleshooting steps to fix printer printing blank pages:
·Restart the printer
·Check printer ink cartridge
·Clean the printer print head
·Update the printer drivers
Follow more steps to fix the Printer printing blank pages issues
Scanner adding blank pages
Driver is probably set for "Skip Blank Page". Adjust "ratio of Black" slider if it is to reduce falsely detected blank pages.
Canon DR9050c: Is double-feeding very frequently despite new rollers (consumables). Only three years old. Problem is new. Has been working well up to this point.
Double feeding is very unlikely with a New set of rollers, as they are clean; however if the fine dust from papers stick to it, it can cause slip. The pickup and the feed rollers push the paper towards the scanning module, while the retard roller initially (in the bottom) pushes it outside. Incase there is a second sheet, it will be pushed out and only one page will enter the scan module.
Slip can take place if the paper is very smooth or has find dust on it. Stapled papers are held together at the point it was stapled, even after the stapler pin has been removed. Ensure all pages are not sticking to each other.
S. Mohan, India
Why when i scan in a batch appears a folder with 4 zeros and the name i assing to the picture o document it finish with 4 zeros to what can be the problem? i alredy uninstall the driver of the scanner and...
This file naming is not a problem, this is intended to be that way. By naming this way, the sequence of scanning is maintained, else the page order will be changed while converting to say, PDF.
Suppose you have 11 pages each numbered 1, 2.....9, 10, 11 etc, when you convert to PDF, the sequence will be 1, 11, 2,3,4, thus the sequence is altered. If the sequence is abcd0001 to abcd0011, after converting to PDF, the SAME sequence will be maintained.
S. Mohan, Chennai, India
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
2answers
Kyocera FS 1010 is printing blank pages
You may need an imaging unit. VERY expensive.
"Skip Blank Page" but still inserts one
I have two of these scanners the only way that i have found round this is to scan the pages duplex then remove the unwanted afterwards!
old marine
old marine
ZJ Limited
ZJ Limited
