The cursor shakes to the point where it is not useable but it only happens when my laptops charger is plugged in. I have tried this with 3 other laptops and it's the same with them.
For me it worked changing tablet mode to : recognition data.
This settings is completelly hidden ( double click the tablet icon and a menu pop up)
I had the same problem and found the solution (for me).
It was the Laptop Power Supply.
Hurray! It also explained why sometimes it would shake, sometimes not and why it also occured on my other laptop which caused me a lot of confusion - I was swapping over the same Power Supply to use on both laptops!
SOURCE: Skipping and Shaking cursor
I had a similar problem years ago w/ my ss III 12x12 that had worked flawlessly for years. I talked to tech support and they said move it away from monitor (crt) or other source of RF interference - this did not help mine. I tried replacing the power supply w/ generic one - no help. I noticed that the power supply voltage was spiking when check w/o load. After talking to an electric guy I know, he suggested a voltage regulator. Finally I built a home-made voltage regulator and wired it into the generic supply line -Problem solved This was about 10 years ago - still working good today.
I have exactly the same problem as you, my tablet worked perfectly for the first three months and then started to act weird, shaking and skipping screen areas, even if i only touch it with my forearm.
Uninstalling/Re-Installing drivers didn't solved anything, so i started switching my tablet to different usb ports in my pc, and from one to another, the problem got a lot better. It didin't solved it, but works "decent". So, comparing yor experience with mine, it's probably an usb-port problem, rather than the tablet itself i thik.
I will test it in othe computerts to see how it goes
I own a Graphire2 and I have often had the cursor shake like this. Usually unplugging and replugging the USB cable from the computer does the trick... and if it doesn't, restarting the computer usually does. I've never really had to fight with drivers.
SOURCE: Have the graphire 3 tablet, Not working well.
Wacom tablet not plugged into your computer with the USB cable.
Go to Add/Remove Programs, (Start>Control Panel>Add/Remove Programs), and -> Remove
the Wacom software.
Restart your computer.
After Windows XP has fully loaded again, install the Wacom Graphire 3 CD, in your CD/DVD drive. Reinstall the software.
If you had to reinstall your Windows XP operating system, you may have corrupted some of the Wacom tablet's drivers. (Hence the shaky stylus cursor) Removing the Wacom software, and reinstalling it will repair.
Now plug the Wacom tablet into your computer.
You should see the, "Found New Hardware", pop-up out of your taskbar tray.
