JVC LT-37X688 37 in. LCD HDTV Logo
Larry Posted on Dec 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
37 Color and picture distortion moving rt to lft across the screen for 10 to 15 min. After turning on. Firmly touching the upper left of the screen will immediately stop the problem, but I t comes back within a minute. Problem has gotten worse over the last month. TV is about 3 years old, maybe 4.
Perry Mellott
Level 2:
  • Expert 147 Answers
  • Posted on Dec 30, 2011
Perry Mellott
Expert
Level 2:
Answers
147
Questions
Helped
78967
Points
339
Sounds like a Tab Issue,Connections are Become Bad on the Inner Connections to the Screen,The Real Fix would be to Replace The Panel
Connector pin color code and connection
ok i have one in my hands and it goes like this blue w white stripe ant cont green rear lft purple rear rt gray frnt rt white frnt lft red pos yellow fuse filter black neg thats what my deck shows and it isnt hacked yet good luck
Radio fuse
# 18 for radio and it is a 20amp...see below for all #'s got to and amps... 1-20amp-pwr outlet frt. 2-10amp-rear fog lights(export only)
3-15 amp-horn 4-10amp-hedlt low beam rt
5-10amp-hedlt low beam lft 6-20amp-bodycontrolmodule/pwr dr locks 7-spare 8-spare 9-10amp- rt pk lt /rt tail lt/trailer tow lt/cluster
10-spare 11-15 amp-flasher 12-15 amp-stop lts
13-10amp-bodycontrolmodule/cmtc/cluster 14-spare
15-10amp-pdc fuel pmp & auto shutdownrelays/skis
16-20amp-pwr outlet rear 17-15amp-rear wiper 18-20amp-radio choke relay 19-20amp-frt fog lts/trailer tow stop and turn lts
20-20amp-sunroof 21-spare 22-10amp-wiperswitch/frt and rear washer 23-10amp-lft park lt/lft tail lt 24-10amp-pdc blower motor relay 25-10amp-heatseatswitch/hvac controlhead/trailor tow battery charge 26-10amp-hedlt highbeam rt 27-10amp-hedlt highbeam lft
28-spare 29-15amp-heated seat module 30-10amp-heated mirrors/rearwindowdefrosterindicator 31-20amp-cigarlighter
32-10amp-radio/frtdoorlockswitches/bodycontrolmodule
33-10amp-skis/diagnostic connector 34-15amp-cluster/courtesy lts/radio/bodycontrolmodule/maplights/cmtc/underhood lt/vanity lts
35-spare 36-10amp-ignition run/start-orc/lft and rt siacm
37-10amp-ignition run only-orc 38-10amp-abs module/brake shift interlock solenoid 39-10amp-rear window defroster relay/flasher/backup lts
26helpful
6answers
2002 jeep liberty interior fuse diagram
2answers
I don't have an owners manual and I need a fuse diagram for my 2002 jeep liberty
There is normally a diagram printed onto the the inside of the fuse case.
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
2answers
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
