Canon DR-2580C Path-Through Scanner Logo
Laverne Sahm Posted on Dec 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not scanning full page - Canon DR-2580C Path-Through Scanner
Mohan Sriraman
Level 2:
  • Expert 490 Answers
  • Posted on Dec 31, 2014
Mohan Sriraman
Expert
Level 2:
Answers
490
Questions
0
Helped
247083
Points
823
Scan with Auto page size
Yellow indicator look like gear lighted on the panel
this is usa forum and we dont have 07 swifts, in USA.
nor any books here, covering that car.
join a forum suzuki in your country or buy the operators guide?
lacking real opr guide book one must try generic pages
lets do that.
over 3 pages full , on page 2 here, is one yellow gear.
http://dashboardsymbols.com/the-symbols/
what that means ,stated clearly in the oper guide too, is get it serviced.
if you have a full DIY shop, then scan it.
or get it scanned.
in all cases, scan it.
that be it , to start.
1helpful
When doing a scan ,how do I group 2 or 3 scans together to create a 2 or 3 page file ?
Mark:
You'll need adobe acrobat (the full program) to open your first page, then open the second page and copy the second page to the bottom of the first page, then copy the third page to the bottom of the second page. If you don't have Adobe Acrobat, have your scanner save the file in another format (such as WinWord), then convert to a PDF file if you need to.
2answers
Hi, I scan documents (recto and recto-verso) using the InformatikScan software and the scanner Canon DR-9080C. When I scan for ex. 30 pages, after 10 pages the scanning process slows down in...
The scanner creates a Raster Image and if it is grey or color, the size is big. After a few images are scanned, the 'buffer' inside the scanner is full. It may take more time to process the scanned image by the scanner if it is 24 bit color. The image is sent to the computer Harddisk and if the disk is full or if it had not been defragged for a long time, the sectors may not be contiguous for speedy writing, This will slow up the scanning. Ensure the disk has large space. 'Scan ahead' slows down scanning speed. (Without scan ahead, the next page is fed only after processing, whereas when selected, just after the previous page is scanned, the scanner start the next one)
S. Mohan, India, Chennai
What does NG mean for Status after sending a scanned item or faxed item?
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
Thanks.
My scanner is scanning in panels, not full pages.
Hi try This
How to reset error 5B00 for Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
All Best: Pineworks
Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Won't scan full page
In the control panel for the scanner, on the bottom left is a button labeled "Specify," where you can adjust how much of the page it scans. Sometimes it is "auto-detect," sometimes it is the size of a small photo, sometimes it is full page. You just have to set it to what you want. Usually auto-detect works, but sometimes it misses and only scans part of a full page, so you have to set it manually to full page.
old marine
old marine
ZJ Limited
ZJ Limited
