When I turn it on, the lens won't come out, until it automatically shuts down.
Try these procedures.
SOURCE: FE-330 THE SHUTTERS KEEPS JAMMING STRANGE NOISE
i am having the same problem with mine , its been like it for the past year now. i am only 14 so my parents think i have dropped it bu i havn't i need a soloution quick because i love taking photos of me and my friends. the olympus f3-330 it a really good cam' but now it doesnt even switch on or turn off . ! you cannot take pictures and the screen comes up in lines and make a beeep beeep noise then the lense goes in and out : / .
SOURCE: when i turn it on.. it says "lens error,will shut
Your camera almost certainly has a lens error, this
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Canon service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault. Although the article
mentions Canon a few times, the advice applies equally to all cameras
with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good
luck, I hope you manage to use this information to fix your camera, or
at least are able to use the information to help decide whether to buy
another camera. If you do
decide that you have to throw your camera away then don't forget to
remove the memory card as it can be used in other devices.
Please take a moment to rate the speedy and free answer I have provided
for you and
any testimonial which you might wish to add is always welcome.
SOURCE: My SX30 IS turn on automatically while inside the
Hiof course not. you have a problem camera. like the type of problem it could involve several circuit trouble shoot. First power control pcb (dc/dc convertor), on/off control switch fpc, and main pcb. I suggest you to send canonUSA or your local repair shop. ( That must be under warrenty, it is pretty new product) Both place would take time in those type of problem. CanonUSA 2 to 3 week usuallly, local 1 to many week depand on what they want to repair.
SOURCE: I HAVE AN A2200 DIGITAL
The A2200 is a piece of garbage. I bought it with the intent of capturing some quick video footage and within a week of purchase, this lens retract issue has happened. The cause was simply from the battery dying while it was recording video! Canon is telling me I now have to send it to a service center, and it potentially could cost as much as a NEW camera to fix. The issue is clearly not my fault, yet I have to pay for it? This is the last time I buy a Canon.
SOURCE: camera says lens error and shuts down immediately.
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
