Computer was working fine. I try to turn it on today, and it says "Reboot and Select proper Boot Device or Insert Boot Media in selected Boot Devise and press a key." I tried pressing "F9" to enter the "recovery mode," but it doesn't work. Did the hard drive crash?
SOURCE: computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
SOURCE: My EEE PC1015 PE keeps giving error message
in situations like this you just must download the correct manual and reinstall the OS,if you have no disk choose a different OS some are virtually cost-free
SOURCE: My name is Henry. I
Go to your BIOS by pressing the delete key as your computer boots up.
Find boot disk priority and set first boot device to your hard drive.
I suggest you unplug any flash drives as you boot the laptop.
SOURCE: I lost my recovery partation
Hi you will need skillful guy to restore your PC Operating system if you had reformatted your hard drive. To restore your O/S without having your recovery CD is to ask from your vendor a copy of it and re-install again. You can do it by having an external DVD driver, change the boot sequence in start up and presto you can reload again your O/S and other applications. Don't forget btw to load the driver in order your PC to work properly.
SOURCE: asus Eee PC 1005PEB
did u select n f8----- last known good conf.....
try to to login in safe mod and roll back the update
do repair installation
