I set a password on my craig tablet and I forgot it.....help me please!
SOURCE: I have forgotten my wireless
Hi!
In order for you to remove the password, you need to reset your wireless router. You didn't mention what brand and model of your router, but anyway all routers have a "reset button" just look for it on your router. It is usually found at the back of the router and it is very small, you need a pin or anything long and thin to insert into it in order to push it for about 10 seconds.
Thanks for using fixya!
SOURCE: Cannot access windows forgot password. I have an
try this link: http://www.fixya.com/support/r5393255-windows_password_recovery
If you have lost
windows password, the best thing for you is creating a password
reset disk.Actually,when you add a password to your pc,the
first thing you should do is creating a disk in case you lost the
password.But how to make a password reset disk after you have lost
the password ? Follow these
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Lost user password in XP with
networking set-up on HP
The best way to do this is using the Offline NT Password &
Registry editor. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
You need to prepare:
1:A blank
CD/DVD or USB flash drive
2.A computer which can link to
internet
3.A program called Windows
Password Key
Then let's begin
Step 1.Login to a PC which
can link to internet,Download and install the program from in that
PC
Step 2.Run the program and burn to CD/DVD OR USB flash
drive
Step 3.Turn to your locked PC,insert the newly create CD or
USB to your drive.Reboot the Computer
and then follow the instructions,it is very easy to use.
You can download it at the following link:
http://pogostick.net/~pnh/ntpasswd/
This
utility will enable you to reset the password of any user that has a
valid (local) account on your Windows NT/2k/XP/Vista etc. system.
The
link above includes some directions on how to use this utility.
This solution works for
most tablets.
Power off the tablet
Tap Power, then press
and hold Power + Vol Down until you get a menu, then release
• Look for a Recovery or Factory Reset option, and select it.*PLEASE NOTE THIS WILL ERASE ALL DATA, INCLUDING THE PASSWORD*
