SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
SOURCE: remove carbon brushes from bosch washing machine
bad news im affraid mackem , depending on what motor your bosch has there is no way to change the carbons without removing the motor .
SOURCE: bosch washing machine
I just did this. Fitting the new brushes was fiddly but not impossible. Its easier if you remove the motor first as this makes access a lot easier.
SOURCE: I'm in need of carbon brushes for my bosch washer
Hello Max,
I`m not sure how you made out since you posted on here at fixya, but I`d like to offer a solution.
Check out my repair tip, it should answer all the questions you may have or had regarding your post.
http://www.fixya.com/support/r5082734-yes_change_some_bosch_washer_motor
let me know if it was helpful for you please. If so rate it favorably. If not, let me know how I can help.
good luck.
macmarkus :)
SOURCE: i have a bosch washing machine model #wfmc1001uc
You shouldn't have to buy a new motor just because the brushes went bad, someone makes the brushes to put in new motors
