Amazon Kindle Wireless Reading Device Logo
mrs sarah mcdowell Posted on Dec 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kindle keeps asking for a wi-fi password for sky37606
Scott Fryer
Level 2:
Scholar:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 106 Answers
  • Posted on Jan 09, 2017
Scott Fryer
Expert
Level 2:
Scholar:
Cheetah:
Answers
106
Questions
0
Helped
27356
Points
212
My monther's issue was because her ISP's (Bell) router, home hub 3000, comes default with the 2.4G and 5G SSID named the same with the same password. So her 2.4G was on a Band that was super weak, like 30%, but her 5G was at 90%. This was causing her wifi connections to use 5G as it was more available. Problem with the kindle is that it is limited to use the 1 - 11 channels / 2.4G only. I resolved this by going to the routers config (192.168.2.1) and changing the SSID from Bell553 to Foxtrot. Then i changed the 5G SSID to Foxtrox-5G and made different passwords for both. Rebooted the router and the kindle was able to connect to the 2.4G network.
Anonymous
Level 2:
Sergeant:
  • Expert 331 Answers
  • Posted on Dec 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
331
Questions
0
Helped
93064
Points
691
If sky37606 is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be sky37606 in confirmation you are connecting to the correct network.
If sky37606 is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
2answers
How do I connect Kindle to WiFi network?
It is so simple just connect the Kindle wifi with password. Sometime due to virus issue Kindle do not connect with the wifi For more you can ask for the Kindle Support Kindle Technical Support Registration 877 690 9305
Lost Wi-Fi on my kindle
You don't give any details. Do you mean you don't have any Wi-Fi at all? Go to the Settings Menu, Select the Wireless & VPN option and see if you are in Airplane mode, if you are turn that off. Then select Wi-Fi. See if Wi-Fi is turned on. If it's not turn it on. There should be a list of available Wi-Fi routers. If one is not selected select one that is open or that you have the password to. If none are open or they are locked and you don't have a password, you'll need to get a password for one, or install your own Wi-Fi router.
2answers
Why doesn't my Kindle Fire 6 recgonize my password?
Amazon.com: Customer Discussions: Kindle Fire won't accept my wi ...
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 16, 2011 - My Kindle Fire recognizes the signal but will not accept my password. I have consulted ..... In reply to an earlier post on Feb 6, 2012 7:32:42 PM PST ... I tried it and the Kindle still doesn't connect with my password. I was on the ... kindle won't connect with wi-fi
May 7, 2012
Help I forgot my password
Apr 11, 2012
Kindle Fire won't recognize wi-fi?
Jan 3, 2012
kindle doesn't recognize Amazon ...
Dec 25, 2011
More results from www.amazon.com
How do I connect to the kindle store my kindle will not connect so I may download kindle books?
To connect to the Kindle Store your device must have either a wi-fi connection to the Internet or a 3G Whispersynch connection via a telecom. Some Kindles come with the 3G and some don't. The ones that don't require a Wi-Fi connection.
So, if you have Wi-Fi access the turn off Airplane mode in Settings and enter the Wi-Fi password to your router. If you are using public Wi-Fi such as at McDonalds you might have to
use the experimental browser in setting to be able to click the *accept terms* button or you will not have access even if connected.
4answers
My kindle wi-fi keeps kicking out. I have G3 and never had to put in a specific wi-fi source. Now it continually asks me to connect, and won't even accept a proper on our home wi-fi router.
Your kindle has a sim card installed for 3G (lifetime licence paid by amazon and paid for on purchase price on the unit) but that is not related to the wi-fi function on your kindle. Your wi-fi service needs to be logged in to with the same password as you use to log any computer on to your router when at home or whatever wi-fi password is required when elsewhere (e.g a bus, train or restaurant).
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Cant acess my wi fi on my kindle fire as it needs my parental password which i cant rember
Not positive but think you will have to unregister the Kindle and then re-register it. You will lose everything.
I can not or do not have a password for the sky wifi how do i get it
If the sky wi-fi is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be the same as you have selected on the Kindle in confirmation you are connecting to the correct network.
If the sky wi-fi is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
2answers
I've only found 1 wi fi network on my kindle and it asks for a password, where do I get the password
From the owner of the Wi-Fi network.The password is usually set up in a network router to limit wireless access to authorized people.
If you have no idea what I am talking about, your Kindle probably located a neighbour's wireless internet access point and you cannot use it without his permission.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
