After taking a photo, i then try to click into it to view, screen is bottom half blue & says processing?? help!
SOURCE: kODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
SOURCE: My digital camera (Kodak c813) says lens error and will not work!
Maybe the lens is intact (stuck).
SOURCE: Kodak EasyShare C653 Camera, cannot connect to my macbook
Try a dig. USB plug,
Try a dif. cable.
Try with a cardreader.
If your cable is faulty it is covered under the same 1 year warranty as the cam.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: Can't view pics on digital frame using new camera
You need to make sure that the pics are on standard jpeg compression, if not try opening file from your pc using mspaint then save file as jpeg
SOURCE: How do i transfer my photos onto my computer once
Close the application Kodak software in your PC; while, kee connected the camera with the USB cable and turn ON, then EXPLORE devices or Disk Devices, the PC must read you Memory Card as one additional Disk Device (as USB), just select the images in your camera "memory card" and copy/paste to the PC's Hard Disk.
I hope this helps to solve it (remenber to rate and comment this).
