I don't have a suggestion, but I do have the same problem. My wife ran the self clean and now neither the bake or the broil function. All other electronics work fine.
I am going to assume that you selected bake as you normally would and there are no faults (error code) reported. - this would mean there would not be a problem with the controller or the temperature sensor. The problem may be with only the bake circuit - so try the broil function - If the broil works then you may have a problem with the bake element or the connections to it or the relay on the controller - check the connections first then the element - If the broil does not work also then you may have a problem with the relay on the controller or the connection of the other leg of the 220v supply.
Make a check or have someone check it and wrte me back a post here
Regards
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
