I found this on the net, i hope this helps you out. It also says that this nasty virus is a tough one...and you still run the risk of ruining your info on the hard drive. Back-up critical info (Docs,Music, Game info etc)
And keep me posted on the results..i hope this helps you out! GOOD LUCK! 8-)
Step 1 : Use Windows File Search Tool to Find Zlob Path
- Go to Start > Search > All Files or Folders.
- In the "All or part of the the file name" section, type in "Zlob" file name(s).
- To get better results, select "Look in: Local Hard Drives" or "Look in: My Computer" and then click "Search" button.
- When Windows finishes your search, hover over the "In Folder" of "Zlob",
highlight the file and copy/paste the path into the address bar. Save the file's path on your clipboard because
you'll need the file path to delete Zlob in the following manual removal steps.
Step 2 : Use Windows Task Manager to Remove Zlob Processes
- To open the Windows Task Manager, use the combination of CTRL+ALT+DEL or CTRL+SHIFT+ESC.
- Click on the "Image Name" button to search for "Zlob" process by name.
- Select the "Zlob" process and click on the "End Process" button to kill it.
- Remove the "Zlob" processes files:
msmsgs.exe
nvctrl.exe
msmsgs.exe
nvctrl.exe
Read more about How to kill Zlob Processes
Step 3 : Use Registry Editor to Remove Zlob Registry Values
- To open the Registry Editor, go to Start > Run > type regedit and then press the "OK" button.
- Locate and delete the entry or entries whose data value (in the rightmost column) is the spyware file(s) detected earlier.
- To delete "Zlob" value, right-click on it and select the "Delete" option.
- Locate and delete "Zlob" registry entries:
HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsNTCurrentVersionWinlogonShell=explorer.exe
HKEY_LOCAL_MACHINE
SoftwareMicrosoftWindows NT CurrentVersionWinlogonShell=explorer.exe,
msmsgs.exeHKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionRunRegSvr32=%System%msmsgs.exe
HKEY_LOCAL_MACHINE
SoftwareMicrosoftWindows CurrentVersionRunRegSvr32=%System%msmsgs.exe
Read more about How to Remove Zlob Registry Entries
Step 4 : Use Windows Command Prompt to Unregister Zlob DLL Files
- To open the Windows Command Prompt, go to Start > Run > type cmd and then click the "OK" button.
- Type "cd" in order to change the current directory, press the "space" button, enter the full path to where you believe the Zlob DLL file is located
and press the "Enter" button on your keyboard. If you don't know where Zlob DLL file is located, use the "dir" command to display the directory's contents.
- To unregister "Zlob" DLL file, type in the exact directory path + "regsvr32 /u" + [DLL_NAME] (for example, :C\Spyware-folder\> regsvr32 /u Zlob.dll) and press the "Enter" button.
A message will pop up that says you successfully unregistered the file.
- Search and unregister "Zlob" DLL files:
uimcu.dll
antzozc.dll
dtjby.dll
Step 5 : Detect and Delete Other Zlob Files
- To open the Windows Command Prompt, go to Start > Run > type cmd and then press the "OK" button.
- Type in "dir /A name_of_the_folder" (for example, C:\Spyware-folder), which will display the folder's content even the hidden files.
- To change directory, type in "cd name_of_the_folder".
- Once you have the file you're looking for type in "del name_of_the_file".
- To delete a file in folder, type in "del name_of_the_file".
- To delete the entire folder, type in "rmdir /S name_of_the_folder".
uimcu.dll
antzozc.dll
dtjby.dll
dumpserv.com
zxserv0.com
vnp7s.net
Protect
RSA
ncompat.tlb
msvol.tlb
hp[X].tmp
msmsgs.exe
nvctrl.exe
dumpserv.com
zxserv0.com
vnp7s.net
%UserProfile%\Application Data\Microsoft\Protect
%UserProfile%\Application Data\Microsoft\Crypto\RSA
ncompat.tlb
msvol.tlb
hp[X].tmp
