The buttons don't work right. Can't change the the fan speed, nor from heat to cool and goes off sometimes and have to turn back on
SOURCE: Not cooling - M7Y15F2A-B
have you done adjusting the thermostat settings & changing the mode settings..?
SOURCE: window air cond unit, several years old, doesn't blow as cold
The problem with window units and any service tech will tell you it cost more to repair than you can buy at Walmart or home depot. Unless you know someone who can charge it for you. Window units are a sore subject. A 200 dollar window unit might cost 200 dollars to charge system. SORRy rusty
SOURCE: Need circuit board for Maytag portable a/c unit
my portable a/c unit works but blows not so cold air what can i do to help it blow colder air
SOURCE: 9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
SOURCE: Maytag M7Y15F2A-D A/C - won't turn on -long beep then nothing
The beeping might be an alarm that indicates the coils are iced over by
too much humidity in the air...and/or the unit is overheating etc.
shut off power to the unit for a few hours, go out somewhere if it is
too stuffy inside.. see if the unit operates better when you return...
I also suggest not running these things constantly, this causes some
units to ice up and **** up the power..
hope the unit does get replaced, newer ones are more efficient.
