SOURCE: I have Brookstones silver bullet
Sometimes the metal weights fall out of the top rotating bar causing the blades to be out of balance and the bottom blade to hit the tail. Check to see if both the weights are in the top bar.
SOURCE: My new u-control helicopter is experencing spinning
how much is it spinning after and if not to much adjust the st. trim on the controller.
SOURCE: The bottom blade's of my
One of the weights on the rotor has fallen off. There should be a silver weight on each end of the top skinny rotor
SOURCE: My silver bullet Brookstone helicopter
yes, you just slowly move the trim button to adjust the spinning. However, it may be due to broken blades. please check the same also.
SOURCE: when i turn on the remote control, the red on/off
The batteries in the controller are nearly flat
