My device p3450 is stock in boot loader and i tried many rom even profissional one is not help which is \r\nDID-ELF010050_CID-DOPOD001_ROM-2.20.721.2B which my device have same info of cid and device number but untel now my device is stock in boot loader that when i try to to update its stop in 3% and it reboot and agine in boot loader stock whith no ruu in top right display but only usb in below disply left and number of old and new rom
You can find official resources for your phone here, and lost of useful informations about it here.
Hope you are able to sort your problems out.
Regards,
Carlos
1.have you gone through the instructions from ROM cookers.
2. put the mob on recharge and try to restart.
3. have u done a hard reset after rom update
4. try xda forum
if ur phone is HTC P3450 ELF or HTC3452 ELFIN there are 2 versions of this device then go to start >Programs>fileExplorer>select music file u want to set as ringtone, and then long tap on the file for like 4 sec a menu will appear u can select set as ringtone and ur file will be set it is the std procedure for it
and about that HTC audio manager u can check for updated ROM from www.htc.com >ur region >support and then check if new ROM is availble it i will address ur issues of audio manager
but if u really want a new look for ur PDA and want to make it like touch HD then my friend i will suggest this but at ur own risk but the results are really worth it
see this update to CUSTOM ROM for ur pda and u will get more free memory for programs and storage i know it is a big rpoblem in this pda and u will get new look like touch hd
I was then able to access my phone using ActiveSync (by connecting via the USB cable) and use the Explore option and copy any photos to my computer by simply 'dragging and dropping them to my desktop.
Hope this helps ! I am a newbie to all this and this worked for me :)
You can only copy files to a blank disk by using programs like NERO or by using a re-writeable disk like DVD-RW which you can format and use it like a hard drive. You need also burner not an ordinary DVD or CD player.
agri-man
low-lable format can solve ur problem.
at first create windows98 startup disk from any win98 pc or use windows98 bootable cd. and download disk manage 9.54 for samsung hard disk. and copy it in a cd. then boot ur pc with windows98 bootable disc or startup disk. then inseart disk manager cd go to cd rom drive give "dm" commnad. run low lable format form advance --->utility ----->maintanance------> low lable format. after complete low lable format (it can take saveral time) then creat partition and format each partion.
you'll have to install a different rom, in fact a WWE one, it stands for world wide english. head on over to www.xda-developers.com and look in the htc elf topic, don't forget to jump-spl the phone before flashing a different rom
