SOURCE: Need New Watch Band
i have repaired watches like this before. I advised u to go to www.the watchery.com and www.lucienpiccardusa.com or www.ebay.com. there u can buy and choose branded lucien piccard watch band.let me know if u see what u wanted...
SOURCE: lucien piccard watch
The arrows you are seeing are for sizing the band. I cannot find 26311SS in my data base, but I have a good idea what you need to do. The curved piece is a safty that goes over the clasp. Take something like a round toothpick and with the curved piece going to the right like this: ( put the toothpick under the far lefthand side, in the middle and see if you can pry it up ,( I say use a tooth pick so not to scratch up your watch) it should flip over to the right.Check and see if there are any spring loaded buttons on either side of the clasp, if there is push them in ,and lift to your left If there is no buttons just pry up towards your left. If this dosn't work PLEASE let me know, and I will find the exact watch and we can go from there. Good luck!!
SOURCE: Add links to a Lucien Piccard 26006SS
You may have
arrows inside bracelet.Arrows are pointing the way the pins must come
out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
SOURCE: Replacing Batteries on Sealed Watches
Who ever told you that story about throwing it away should not be in the business of repairing watches. I have the same problem and googled Lucienpiccardusa.com. They do lifetime battery replacement and some general servicing according to your warrenty. From what I read on their web site you only pay for the shipping charges.
Hope this helps you. JFG
SOURCE: Lucien Piccard 27094bk manual
Go to the web site "lucienpiccardusa.com/"
From the menu on the left select "customer care".
Scroll down the page until you find "instruction downloads"
Choose "three stage movement instructs"
If this is not quite what you need, you could email them.
