Computers & Internet Logo
Posted on Dec 26, 2017
Sony SDX560VRB AIT-2 Turbo Tape Drive - Internal IDE VERY SLOW
For years I have sucessfully been using a external USB sony AIT drive, I recently installed a new internal IDE Sony ait drive. It runs much slower than the old drive and REALLY slows down the whole computer! IE explorer takes 30 seconds to load!
Any ideas why?
Thanks a lot to you.
  • ravilious Oct 04, 2008
    tHANKS
  • Anonymous May 11, 2010
    Are the hard disk and tape drives in same cable? thanks
2 Related Answers
A
Anonymous
  • Posted on Jan 24, 2008
SOURCE: AIT ERRORS
I had/have a similar problem with a SONY SDX-700C.
Emailed Sony tech support (very helpful) who suggested sending them the diagnostics from their TapeTool utility (qv). They then recommended running the cleaning tape 3 times, which seems to get it working (but the 'clean me' light still comes on every 7-10 backups). Hope this helps.
mrbios
  • 24 Answers
  • Posted on Jan 23, 2010
SOURCE: When I insert a tape - it loads and displays
Try blowing the dust out.  If it needs more than that consider buying a new name brand unit.
Ive just bought an old sony dat drive SDT-5000 and want to use the external housing frome one I already have. Does anyone know how to set the jumpers? I can supply an image of this if it helps
supply an image (and would be great if you could supply image from old broken one and new one)
I'm a bit confused though: if you have an internal working sdt-5000 that you want to put into an external broken sdt-5000, it should be as simple as getting the enclosure open, then swapping the internal drives; i.e. external enclosures usually still use the same spec internal drive so it would just be an ide or scsi connector cable.
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
AIT-3 Tape Ejects when they put in MSSQL 4027
You will not find the list of the error codes on the internet. I know that Error Code: 0x81 is a "Reel" problem as I was just told by Sony Support. You should call them, have you serial number at hand when you do so. Check http://sony.storagesupport.com/ for a Telephone contact number.
Good luck, Bruno
4helpful
How to repair my sony mp5 not working
the only way to fix the problem regarding the mp4 player, is by reprogramming the device.=>
Lib-152E autoloader no longer recognized after firmware update.
Try taking the dives out, connecting each one to your SCSI card and updating the firmware - wait at least 10 minutes afet Tape Tools says you can now use it again! This last bit is very important! Then, after you have done the update to each drive, replace the drives and try again.
I had the same problem with a TSL-SA500C and it woked fr me.
Tim
AIT ERRORS
1helpful
Sony AIT2 Turbo tapes won't work in HP AIT2 tape drives
Hi Paul
It sounds like you have bought the wrong media!
The AIT2 and AIT2 Turbo drives are NOT THE SAME !
for the AIT2 drive (SDX-500C/V SDX-520C/V) you ned the SDX-50C media as the turbo tapes are NOT compatible
If you actually have a turbo drive then you may have a load mech issue in thich case try www.tape-drive-repair for more help as they are good price wise
2answers
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
