Even when the power is off at panel water flows until plug is pulled!
Hi Thanks
for using FixYa. OE is overflow error which occurs when the water level is too high. It can be cleared by
turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub
is drained for 2 minutes if a frequency of more than 25 KHz is detected.
If the issue remains then clean the drain pump located at the front lower
panel. Please revert back for further assistance. Thanks Rylee
