Hi
Thanks for using FixYa. The first
thing that should be checked is if its draining properly as it could be that
the drain hose is clogged and needs to be cleaned. The drain pump also should
not be clogged. Also the stopcock should be opened fully and the water inlet
valve should be checked for any clogs. Also the metal
filter, impeller cover and the air gap unit should be checked. After
checking this you can reset the error as follows: turn the
rotary selector switch to "Stop/End" or press the "Start/Stop"
switch for approx. 5 secs. Then switch the appliance off and then back on
again. Please revert back for further assistance.
Thanks
Rylee
