Question about Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA
How to reset temp alarm on a freezer - Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Jul 09, 2017 | Kenmore Freezers
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA Logo
119 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
