Fisher and Paykel IWL12 Top Load Washer Logo
Michelle Posted on Dec 22, 2011
WL70T60 spanner light on
Havent had any problems until this evening, put a small load of washing in, it filled up with cold water and then all of a sudden the machine just started beeping contiually and then a Red Spanner Button come up and no amount of re-setting the Machine has fixed it (still currently has the water in it). Model: WL70T60 Fisher & Paykel AquaSmart 7L. Any Suggestions? Cant really afford a Call-Out/Labourer at this time so any Suggestions would be Great....
2 Related Answers
Anonymous
  • Posted on Nov 18, 2009
SOURCE: fisher@paykel aquasmart WL80T65CW1 fault code245
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
luisa_sgro
  • 713 Answers
  • Posted on Jul 10, 2010
SOURCE: Fisher and Paykel WL80T65D washing machine won't fill or spin
Hi just read your posting.Now when the red spanner light was flashing were there any other lights that were on.If there was then they will be in your cycle selection row.This row has 8 lights on it.Starting from left to right what lights were lit?Is it the 1st and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I can help you rectify this problem.
Why won't it do cold wash?
check replace inlet water solenoid unless you hear it click on when you start the machine , there is no power to it or it is faulty and not operating to open the water valve
My F&P GB 712 top-loader worked perfectly until we washed 2 small little mats causing an off-balanced load and severe trembling. Since then cold water only seeps in while the hot water supply is normal...
2 things- balance and 'poor cold fill'!
Normally most 'Off balance' loads should eventually be balanced by the machine so I would advise checking and, if necessary, adjusting the machine's overall balance:-
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
Poor cold fill (for 'hot and cold' read just 'cold'!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
1helpful
2answers
My Aquasmart WL80T65D washing machine, stopped during a spin cycle and started beeping every second with a red spanner light flashing. I followed the manuals instructions to turn the machine off for a...
Hi just read your fault.Now from the information in your posting the lights that are on when the machine is beeping are the 3,4 and 8th lights.Now these lights are in a row of 8 lights and you started from the left.So from left to right the lights that are lit when the machine is beeping are 3,4,and 8.Is this correct?If it is correct then the fault on your machine is called COLD VALVE FAULT.The 3 reasons why this fault occurs is, 1st the wiring to the water valves is faulty,the 2nd is the cold water valve is faulty, or 3rd the control module is faulty.Have you or can you borrow an electrical test meter so I can help you narrow down which is causing the fault.Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
2helpful
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
1helpful
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
My washing machine is leaking water even with the water shut off and the amchine not running. Is this a drain pipe problem or a oump proplem or another problem?
Hello there
whaen awashing machine does not stop putting water into a machine even after it has stopped then this means that the water fill valve needs to be replaced or repaired this valve has 2 small solinoid valves on it one for hot and one for cold and over time they will start to fail and the result is water entering the machine even after it is off looks like this b9e1869.jpg
1helpful
Green whites?
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Over loading the washer: Even if the agitator is suppose to go back and forth, the clothes are not. If you can hold the lid button on your washer so you can watch the clothes wash, they should 'roll" in the basket and not go back and forth like the agitator. The clothes will go down the side of the agitator, across the bottom of the basket, up the side of the basket and across the top of the water in a rolling motion. Overloading is not just too many clothes but also too little water for the size of the load is another way of having a overloaded wash load.
Water temp is important: Use a thermometer to test the temp of the incoming water in your washer. Hot water should be close to 140 degrees F. Warm water fill should be 100 degrees F. Cold water is approx 60-80 degrees F. What happens in a cold climate location is the cold water temp drops as the outside temps drops, once the water temp gets below 60 degrees F, it can no longer dissolve the soap properly and will most definitely leave "whiting" on the clothes!! Do not use a cold wash, wash your clothes in as warm as poss.  water as they can take. If you have delicates you want to wash in cold, start washer out with warm water as you are putting in the soap and fabric softener and clothes, then switch to cold to let it finish filling up, this will give you a warmer wash but not as cold as straight cold water. I find most washes can be done in a warm wash / cold rinse just fine. If you need ( and probably will ) to adjust your warm water fill, turn on the hot water tap fully, turn off the cold water tap. Let the water start to fill on a warm wash setting. Then slowly turn on the cold tap adding the cold water to the hot water making a warm fill....use a thermometer to set water temp and leave the taps stay when you get about 100 degree F water fill. I adjust my own washer usually twice a year, one on summer time and once in the dead of winter.
Test for too much soap or soap retention: Put in a load of towels or dark clothing that has been bad for the "whiting" problem. These items are bad for holding soap and getting what is called -soap retention-
Wash the load in the warmest poss. water, DO NOT add any soap. Let the washer fill with water and wash for approx. 5 minutes, lift the lid and observe what is on the top of the water. If you see soap and bubbles on top of the water, your clothes have soap retention, this soap came out of your clothes. Let the load finish with out adding any soap and wash all clothes effected with this "whiting" residue. Once all the soap is washed out of the fabric and you start to add some to each load, use about 1/2 of what the box says. Liquid soap has less problems with "whiting" than the powder does, but I find powder soap is better at getting my own personal clothes cleaner.
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Small brown spots on whites
Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
