Need the speaker diagram for a chevy 97 tahoe cause the speakers worked when the factory radio worked and now that we are changing the radio in it the center speakers dont want to work know and they did before so i need the wiring diagram for the speakers and a picture to if possible.
Those are not the right colors on the back passenger door it's red and tan so not sure what's positive and negative there
1997 Chevrolet Tahoe Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6 1/2? Speakers
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
SOURCE: No sound from my 2005 Corolla speakers
The likely problem is that somehow one of the wires going to the speakers has "grounded out", meaning a wire for some reason is touching the car chassis, therefore shorting out the circuit the same way a lightning rod conducts the lighting into the ground, instead of your home.
A decent car stereo installer should be able to determine the problem. Either it's grounded out, which they can use a meter and connect the probes between ground and each of the 8 speaker wires to determine -or- the radio is faulty, and a new radio can be as cheap as $150, +fit kit, + wiring harness. Don't buy a factory radio replacement because it is a huge rip off and aftermarket ones are much better.
SOURCE: my radio
could be a short across your speaker terinals.are u using a seperate amp.got to be more specific on set up
some times in trunk metal from something might bre touching the terminal on speakers ,this will cause a muted affect also check to make sure you didnt mute the radio.
SOURCE: Chevy Tahoe radio wiring problems
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
SOURCE: new cd player installed but no sound!!!!!
First be sure thet all wires are properly connected and that the units output sound controls are adjusted
(balance & fade etc.)
www.installdr.com has many valueable resources that may assist you.
Good luck
