My camera does not remember the date that is set. Each time it is switched on it asks me to set the date and time? It often asks me to change the batteries even though they are fully charges
SOURCE: My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Testimonial: "Thank you Viscam tech. it is working. :)"
SOURCE: Kodak Z700 not firing up
Guest is right. Clean the contacts, bend the contacts with a small flat head screw driver upwards "GENTLY". This should work. Might have to repeat every couple of months. Forget regular batteries. Use the rechargeable ones. MUST be fully recharged.
SOURCE: switching off as if battery is depleted when the battery is newly charged
I called Pentax and they said it's a known problem and the lens needs to be re-synchronized. They said this is usually caused by dust in the lens.
I have to send the camera to : -
Pentax U.K. Limited
Pentax House
Heron Drive
Langley
Slough
SL3 8P
It's a free repair if you bought the camera less than a year ago o/w they will send you a quote for the repair.
