SOURCE: why cant i install blitzkreig
try installing your game in compatibility mode.
Running from a disc:
right click on disc>open>(find the installer for the game usually installer.exe)>right click on the installer>properties>compatibility tab>(click the box to run in compatibility mode and try running your software with XP SP3).
If you are installing from a file then just follow the same steps, find the installer in the downloaded folder...............
SOURCE: I recently tried to reinstall
Welcome to Fixya
Reinstall the driver of your video card. make sure that your driver is suitable for windows 7 64 bit operating system,.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: Is there a driver/file available
If it's a DOS based game (which I believe it is based on what I'm reading), you'll need to install a DOS emulator. I believe DosBox http://www.dosbox.com/ is popular, but there are a few others if you search around.
SOURCE: The Game crashes on WIndows
The game has certain compatibility issues with Windows 7.Several users has got this problem. I suggest you to contact Microsoft for a solution.
Regards,
Muhaim
Windows Vista or Windows 7, will have problems running some older versions of applications, just because so much has changed under the hood from Windows XP days. Thankfully there is a compatibility mode that can be easily set per application.
To configure the compatibility mode for an application, just locate the installation directory and right click on the .exe, selecting Properties from the menu. THEN select your compatibility tab, You can choose to run the program in Windows XP compatibility mode, or even all the way back to Windows 95 compatibility.
Probably the most useful setting to start off with would be to disable the visual themes and desktop composition, if you can't get things working. If you are trying to run a video game, you will often need to choose "Run this program as an administrator". You'll have to play around with it, but most likely you can get your application working this way. Also, you will be able to make a selection for windows VISTA which is backwards and forwards compatible with WINDOWS 7
