You don't know the security code? You can reset the phone using the master reset code,get the master reset code from the site Unlock-free.com and reset from security lock of NOKIA DCT or ALCTEL phones.
You can set up a security code to lock your Nokia 6288 keypad in case a thief tries to call from your stolen phone
Published on Mar 14, 2007
You can set up a security code to lock your Nokia 6280's keypad in case your phone opens in your pocket and calls one of your contacts, annoying them and potentially running up a huge bill.
The code will also stop a thief from using your stolen Nokia 6280 to run up a huge phone bill before you can alert your network provider.
To set the security code, click Menu > Settings > Phone > Security keyguard. You'll be prompted for the Security code. By default this is 12345. Enter this and press OK. Select On and click Select to see the message 'Security keyguard activated'.
Now when you slide your phone shut and press Lock, you'll see the message 'Keypad locked with security code'.
When you slide it open, you'll be prompted to enter the security code. Type your code and click OK to activate your keypad.
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed'. Hope this helps.
Enter the default security code -12345.
If the phone does not opens, or you have changed the security code, enter the other security code and after it accepts the code, do the following setting to remove the setting.
Goto Menu>>Settings>>Phone Settings>> Key guard Settings>> Key guard code>>OFF.
(enter the same code that you used at the beginning).
You need to enter the security code if your phone is asking you. If you don't remember your security code or you don't put a code try to enter the default security code. The default code is "12345". If this code not worked, it only means that you change your security code. If you cant recover your code, you better bring it to a phone technician. They know how to fix this problem.
hi....
if u have buy vew nokia 5200 then go to phone settings
menu>settings>phone settings>security keyguard>security code:12345>on
you can change this code from menu>settings> security>access codes>change security code>enter old code:12345>then enter new code.
Go to the site http://unlockme.co.uk and enter your phone’s IMIE number and press Enter then u’ll get the master code of your phone. 2. This master code can be used as lock code when we are asked for the security code. 3.But always we can’t remember master code and we want to use an easier lock-code then we can set a new security code of our own wish by giving the Master-code as our old security code when asked for old code while resetting security code. e.g.NOKIA 6600 Tools -> Settings ->(scroll down) security -> Phone and SIM ->(scroll down) Lock Code Then it asks for old code where u can type the master code and then set the new code as you wish. When during formatting u are asked for lock code you can also enter Master code. To get IMIE of your phone type *#06# on screen of your phones.
Enter the Security Code, press OK. NOTE: The default security code is 0000.
Setting the PIN Code:
From the standby screen, press Menu.
Scroll to and select Settings.
Scroll to and select PIN Code Request.
Scroll to and select On.
Enter the PIN code, press OK. NOTE: Default PIN code is 1111.
Changing the Security Code:
Scroll to and select Change Codes.
Scroll to and select Security Code.
Enter the current Security Code, press OK. NOTE: The default security code is 0000.
Enter in the New security code, press OK.
Confirm Security Code, press OK.
IMPORTANT: If the incorrect lock code is entered more than 3 times the phone will display "ENTER PUK". If this message is displayed contact Customer Care.
