Kodak 1550
SOURCE: kodak c613
Try Easyshare 6. 45MB d/l though
http://www.kodak.com/global/en/service/downloads/dln_ekn030260.jhtml?operatingSystem=windows_2000&downloadLanguage=en
SOURCE: kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: Kodak Easyshare camera turns on and off
Yes you are. My wife denied that she dropped in the sand but I found a list of photos that she wanted to print on a post-it paper in the cover and it had sand all over the sticky part. Used the pressure air spray to clean the rings and it is back to life. Well It worked but there was some problem during zoom in&out, so I spray the rings while zooming and out and that cleaned it. I hope I don't have to open it to clean the mechanism. Thank you.
SOURCE: kodak digital camera V705 -error 45
Hi!
E45 means that a focus error occurred or the MCU BOARD malfunctioned. I'm afraid you will have to give it away for a repair. It's a hardware problem. You should contact your local Kodak service center.
Tom
