Kirby Ultimate G Bagged Upright Vacuum Logo
Rocky Posted on Dec 17, 2011
Kirby bag - Kirby Ultimate G Bagged Upright Vacuum
How to replace filler tube on Kirby G4 vacuum?
first take cloth bag off, held on at bottom with bag clamp, then wash cloth bag in washing machine at 40, inner hose is held on by 2 cable ties top and bottom, your new hose should come with 2 new cable ties, ask kirby agent when ordering, them simply refit.
6helpful
Can you give me a list of Kirby vacs models & the year they were released so that I know how old they are?
1935 KIRBY Model R*
19?? KIRBY Model 2R
19?? KIRBY Model 3R
19?? KIRBY Model 4R
19?? KIRBY Model C
1939 KIRBY Model 2C
19?? KIRBY Model 3C
19?? KIRBY Model 4C
Model 505 - 1945
Model 508 - 1948
Model 509 - 1949
Model 510 - 1950
Model 511 - 1951
Model 512 - 1952
Model 513 - 1953
Model 514 - 1954
Model 515 - 1955
Model 516 - 1956
Model 517 - 1957
Model 518 - 1958
Model 519 – 1959
Model 560 - 1960
Model 561 - 1961
Model 562 - 1962
1963/64 Sanitronic VII (Sirocco)
1965-67 Dual Sanitronic 50 (Sirocco)
1967-70 Dual Sanitronic 80 (Avocado green)
1970-73 Classic 1CR (Medium brown, gold bag)
1973-76 Classic Omega 1CB (Dark brown, dark brown pinstriped bag)
1976-79 Classic III 2CB (Candy-apple red, plaid bag)
1979-81 Tradition (Dark blue; intro of paper bag)
1981-84 Heritage (Gray/orange)
1984-89 Heritage II Legend (Charcoal/gray/red)
1989-90 Legend II (Dark rose-pink)
1990-93 Generation 3 (Alabaster)
1993-96 Generation 4 (Medium gray)
1996-99 Generation 5 (Maroon)
1999-01 Generation 6 (Black/Yellow)
2002-05 Kirby Ultimate G
2005-06 Kirby Ultimate G Diamond
http://www.vacuumwizard.com/history-of-kirby-vacuum-cleaners.html
2answers
I broke the zipper on the cloth bag on my kirby gen. 3 can i replace this myself
Yes.
To order Kirby vacuum bags, replacement parts, or cleaning products, please visit your local independent Kirby Distributor, or call:”
1-800-437-7170 United States and Canada
2helpful
2answers
Kirby G4 Vacuum "BOOT"?
Greetings from GoVacuum,
The bottom part of the bag, which you referred to as a "Boot" is actually called a Kirby G4 Mini Em-Tor with Fill Tube Assembly. Kirby Part # 199493S. The part is only available to purchase with the fill tube assembly, this is the part that the disposable paper bag connects to inside the cloth outer bag.
Kirby has redesigned this fill tube, as the original design sometimes would cause the inner fill tube to crack. The Mini Em-Tor Fill Tube Assembly, part 199493S comes already assembled with the "boot" at the bottom, and the vacuum bag collar (the part the bag actually attaches to) at the top of it. You will need to remove the cloth outer bag from your old part, and put it onto the new "Boot". The cloth bag connects the "boot" with a special zip tie, which is Kirby Vacuum Bag Clamp. Kirby Part # 196599S. Where it is possible to remove the bag clamp without breaking it, I will warn you that this is no easy task. Spare yourself the aggravation of having to try and remove the clamp, and just cut the bag clamp with a knife or scissors.
You will also have to remove the top of the bag collar at the top of the cloth bag by releasing the fill tube from the inside of the cloth bag.
All of the parts are located on our website, www.govacuum.com. If you have any questions about the repair, you can get me on a live help, chat service located in the top right corner of our website. I'd be happy to walk you through this.
Thanks,
Chris Jones
GoVacuum.com
Kirby Sentria
When you replace the outer bag assembly, you have to make sure that it is turned clockwise untill it fully stops. There is a small switch on body of the Kirby that is only engaged when the bag assembly is installed correctly
2answers
Kirby G4 plugged????
Take the bag off of the vacuum, remove the paper bag, clean out the bag tube then put back on. Make sure that the tube is broken, it is, replave it.
2answers
Cleaning Bag holder for Kirby G4
Take the ring from the bag re-move bag and put in a small bucket of water and let soak for about 1 hour and than remove rinse and let dry on a long slim container or counter.
Kirby G 6 but it only blows air out, no suction. Also how do you detach the cloth bag to wash it?
I have the solution for the cloth bag laundering process...
Here is a link to my guide for cleaning the Kirby cloth bag...
http://reviews.ebay.com/DEODORIZING-CLEA...
It should be helpful. :0)
The Tech Drive problem SHOULD be able to be fixed easily and fairly cheaply by a vac shop or Kirby distributor. There is an adjustment that needs to be made, but it shouldn't require purchasing any parts.
Marci
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
