Dear Expert, I have a major problem with my ARGS7650SS Amana Stove. F3 shows up whenever I press any of the buttons: broil, bake or self clean. Sometimes I am able to heat it to 350 degrees but then in few minutes it's turns off by itself and after that happens I cannot use any of the buttons. I replaced temperature sensor, but the problems still persists. What should I do? Thank you very very much in advance.
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
same as above
