When I try to turn on the power, all I get are these clicking sounds about 3 - 4 seconds apart. This goes on forever now. In the beginning, it makes these clicking sounds for about a minute and then turns on. Then, the delay got longer and longer and now it won't turn on at all. I tried looking in the back to find any obvious signs of a blown capacitor, but I don't see any faults. I don't have any test equipment to check... plus, I'm afraid of tinkering with it too much. I'm not a TV expert. Is this fixable on my own or do I have to take to an expert. Checking online, there are easy fixes for earlier models of the Samsung TV line, but this 8000 series seems complex. Help?
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
SOURCE: Samsung 50" plasma won't turn on
My 42" plasma is making a clicking sound, then it switches off and keeps clicking but not switching back on, when it does go back on it stays on for just a few moments, it is only 14months old.
SOURCE: Samsung HCM 4215W when on, no picture timer blinks & chirp sounds
Sounds like a shorted component in the power supply or the high voltage circuit.
Time to call a professional.
SOURCE: samsung DLP TV won't turn on
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
