For media files maximum volume is very low. how to increase the same.
SOURCE: Lg ke 970 volume
I tend to keep mine on outdoor setting - (under profiles where you silence etc) and i find this setting loud enough. hope this helps.
SOURCE: ring volume too low
Here is how you change your ring volum/sound, message volum/sound and videocall volum/sound on your LG kc910 Renoir:
Hope this was helpful. Good luck.
SOURCE: I have a z550i,my media player volume is too low,i
1. Remove the battery and restart your mobile!
2. Start the media player and goto the "Options / Settings".
3. Select the 'Equalizer' option.
4. Change it from 'Normal' to any other type, like Opera, Jazz, Dance, etc.
5. Now, check the difference in volume of media player!
please rate this advice if it helps ...tc! :)
SOURCE: are e71 speakers really low in volume despite being in max rngtne
Hi!
This can be due to the phone speaker. It might be faulty or in need for replacement. You can try to visit a phone service center to have it check or if you are capable then you can check it yourself.
Please leave comments.
Thank you for reaching us.
SOURCE: My Nokia 5230's volume suddenly went very low.
Please see if there is dirt clogging on the earpiece that would have reduced the volume from the speaker. If so use a pin and soft cotton to clean or you must open the cover and use a brush and air jet.
Secondly the possible weakness of the speaker/earpiece or the weakness of the low power output amplifier is another possibility.
