Ink absorber is full contact service" this message appeared whenever i print paper works & i can't continue printing because of this problem please help
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Hope you find this information helpful.
The printer has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example.
Eight flashes indicates that the ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.
Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Press the RESUME/CANCEL button to cancel the error so you can continue printing.Before the ink absorber becomes completely full, contact a Canon service representative. (You will need to replace a particular part of the printer.)Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts. Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears. You need to bring your printer to the nearest service center to get waste ink absorber replaced.
waste ink absorber error message can sometimes be solved by resetting the printer itself. i havent yet tried in ip1880 but in ip1200, th e resetting method is this: (it might also work on other models)
1. unplug the power cord and the data cable(printer to pc)
2. while press-holding the (printer) power button plug the power cable (do not release printer power button until step 3)
3. press 'resumet' ( the button below the power button of the printer) button twice...
4. release the power button
5. connect the usb cable of the printer to the pc...
- a new canon printer shall be found in the list of printers. use it as default printer
The machine has a built-in ink absorber to hold the ink used during Print Head Cleaning, for example.
This error message indicates that the ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
However, because printing is disabled once the ink absorber becomes completely full and until the ink absorber is replaced, you are recommended to contact your Canon service representative as early as possible. (You will need to replace a particular part of the machine.)
You need to Remove the ink Cartridge first in order for the code to take effect. 1) Closethe print head cover. 2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.) 4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.) 5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0. 6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.) 7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.) 8) Power off then back on and test. 9) Congrats!!
Prepared By Jeffrey Vicada(EDS- Technical Engineer) Philippines
i have the same problem also
My Canon Pixma iP1880 suddenly come out services error 6000. Can any person help me fix this problem. tq...
