HI I HAVE A DVD RECORDER HARD DRIVE I LIVE IN SPAIN AT THE MOMENT I WOULD LIKE TO RECORD AND WATCH TV AT THE SAME TIME IS THIS POSSIBLE, IF IT IS CAN YOU TELL ME HOW TO DO IT.
THANK YOU
SANDRA DRINKWATER
This depends on how your video signals are delivered to the box, in most cases terrestrial TV signals received by ariel, cable are passed through the recorder, then to your TV, this means you can record 1 channel on the box and view another, it appears that this recorder only has 1 tuner so you cannot record 1 station and watch another on the output of this box.
with regard to freeview / satellite tuning, these are connected directly to the DVR and they only have 1 channel to view at a time, so unless you acquire a satellite / cable tuner which allows for dual channels or if you acquire a second cable/sattelite box from your provider it is not possible to record 1 channel and view annother
so this problem can be circumvented with other products, but the expense may be more than you expected, as most cable / sattelite provders will charge to provide a second box. also you will also have to be aware of interfeerance with remotes if 2 sat boxes are used. as the remotes are likly to be similar.
