If you use timer record then go into the timer section by clicking the [timer] button and setup your recordings (check manual) then click [timer] button again to come back to live TV.
If you want to look at the last 6 hours buffer click the [info] button and go surf, and even set areas to record to hard drive (read manual). Press [tuner] button to go back to live TV.
If you want to look at previous recordings on hard drive click the [browser] button and go pick one. [Play] to watch a recording then [stop] to go back to the browser. click [browser] button again to go back to live TV.
NOTE: the time given on the right of a picture in the browser is the length of the recording not the start or end time.
If you want to look at recordings on a DVD disc press the [menu] button (or browser button => disc tray). Watch content then press [stop] to go back to menu. Click [menu] button (or [browser] button) to go back to live TV.
If you want to edit titles and categories click [edit] button in browser menu.
If you want to edit titles chapters and hidden sections click [edit] button while playing a recording.
Always click edit button again to return to previous position (playing or browsing)
It won't let you.
it is very hard to configure that product.
might want to read comments from other people that have the same product as yours.
You can watch a channel and record from a different channel only if you connect antenna and wiring in the right way.
Connect antenna, or receiver box output to recorder input, or ensure it is already connected in the right way.
Connect DVD RW output to TV input, and eventually antenna output on DVD to antenna input on TV.
Put a blank CD inside and program the timer on DVD rw as shown in manual.
Watch TV, the DVD will record from selected channel at selected time without breaking the program on TV.
You can record a channel and watch the same channel at the same time. I will have to look into this more to see if theres another way.
I suppose you got your connectors setup fine.
Simultaneous record and play function.
watching other tv programmes
if there is no other device connected to ext2 aux, pressing TV/HDD will switch to the tv mode.
use the tvs channel up and down button to select a diffrent tv channel.
it should keep recording the channel set to record and you should be able to browse other channels and record the one you want.
