Canon pixma mp760 code for overflow reset
There is no need to change the ink absorbing sponges at all ,,as i hve solved this problem myself for many of my clients i m sure that it will work for u too if followed properly step by step:
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
reset sequence for a MP760 printer that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
ur printer absorber will reset and will work properly and u will be back to work.try doing it one more time if u miss something .
please take a moment to rate the solution after u get ur problem solved
Hello!
I understand that you need the overflow storage emptied?
##341 Maintenance jet waste ink capacity full
Solution: Replace the waste ink absorber as follows in the error occurs:
(1) Select [7] PRINTER TEST in the service mode and select [5] INK ABS CAPA under the [7], then
input “0”.
(2) Check to make sure that no image exist in memory; then, turn off the power, remove the appropriate
parts, and replace the waste ink absorber.
##342 Cleaning absorption waste ink capacity full
input “0”.
I can give you a link to a manual with pictures and procedures on maintenance:
http://www.usa.canon.com/consumer/contro...
If you have any further questions just ask
Also Please Don't forget to rate my solution if you don't have any further questions!
Hope I was been able to help!
The tank is really an absorbent pad. In some printers it is very difficult to get at and replace, and in others a reasonably handy person can do it.
You can get away with simply resetting the printer memory once without replacing or cleaning the "tank."
Unfortunately, the cost of having a tech do it is often close to the replacement cost for a new printer.
If you want to try to do the reset code you must do it when you get the warning. If you keep
printing, some models will stop funtioning and you can not reset it at that point.
Follow my or techgurus instructions to reset the error.
Here is how to reset the overflow error:
http://i35.photobucket.com/albums/d192/M...
The previouse link doesn't work for some reason, but there was a picture with details:
One more time:
click here to see big picture
Well that would be good but I need the code to reset the printer.
There are alot of sponges to replace and would like as much info on this as possible.
Message on printer is waste ink counter resetting. It says print out the EEPROM information and select #7 PRINTER in the service mode the register at #5 INK ABS CAPA.
NEED THE CODE.
Hi again can you explain to me how to change absorber pads. I can't find anywhere in net to show location or how to best attempt this. How do I do a rating?
I also tried the above link and it didn't show a diagram. Rating 8/10
canon mp760 printer. ink waste absorber full.
I have purchased absorber sponges and I need to see a diagram of where they go. Or an explaination of how to do it. I have the service manual which explains what numbers to punch in when done etc. I am prepared to pay full amount, I'm just not sure what I have to do to upgrade this service. Please let me know. I have wasted enough time on this. I have lots of work to do. Thank you
Hi still need to see a diagram. I already have this service manual and desperately need to know how to get to the one with diagrams.. Please help
