SOURCE: I cannot connect Amazon Kindle to my router. The
Are you using WEP 1 or WEP2 on your router? It may be that the Kindle doesn't like one or the other.
Also check to make sure that when you put the key in, you are following the case of the key, as they are case sensitive.
SOURCE: wirelss router won't allow other
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
