My Epson Stylus Photo 1800 prints texts from Microsoft Word 2000 and PDF files from Adobe Reader 6, but when I try to print images from Paint Shop Pro 9 I always get a false paper jam message . I have reinstalled the printer driver and the PSP program without solving the problem. I have used the printer for a few years without any problem.
This link might help you. False paper jam Epson Stylus Photo 1800 Google Search
SOURCE: My Epson r220 photo printer is giving false paper
the false paper jam problem is creating by paper out cansor so please this is the repairing mater you care it a repairing shop.
SOURCE: e-studio4511 won't print more than 1 page of a pdf file at once.
download the latest PS driver off toshibas website, due to adobe 9 update this is a known issue, newest driver should fix
SOURCE: Mac OS 10.5 Leopard
You will nee the latest version of Print CD version 1.6 or above. Version 2 can now be downloaded from the Epson website free of charge. You will also need the latest Easy Print Module and latest printer driver.
SOURCE: Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets
1.
Open the paper support and raise the extension.
2.
Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams.
Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time.
Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.)
4.
Open the output tray and pull out the extension.
You should also follow these guidelines:
Always load the short edge first, even when you’re printing landscape-oriented pictures.
When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package.
Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
SOURCE: Epson Stylus Photo R260 doesn't complete prints
I have the same problem with my Epson T10. All the papers on the feeder will feed altogether even I am just printing a page. Some technician told me that my printer needs to be aligned on the feeder mechanical part.
