Question about Cell Phones
My laptop doesn't have a CD reader. I bought the D-Link T-Mobile TM-G5240. Where do I install it?
    New Friend:
  • 126 Answers
Hi you`ll need to put the cd on a pc with a cd rom the copy it to a flash drive a an external harddrive then put it in the laptop and install it
Posted on Dec 16, 2011
Testimonial: "Thank you!"
6ya staff
SOURCE:
TM-G5240 router is slow
Is it the wireless device or your ISP? Location the same on wireless device? Computer same place? Channel the same? Antenna the same? Cables the same? You will never get what is advertised. That would under perfect conditions and the Max it will work. Figure the miles of cables and equipment between you and the ISP and all the places it could degrade a signal. Try a High location for the device, change channels.
Jan 02, 2013 | D-Link Tmobile Hotspot Tmg5240 Wireless...
Base system device drivers for lenovo 3000n100 not installed
Try installing the chipset driver which should resolve your issue:
http://driverscollection.com/?file_cid=4009509306067652d2fc76c976e
Scroll half way down the page, enter the code and click download.
If this doesn't work try installing the camera and card reader driver from the following link:
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-63572
If not try installing the camera and card reader driver from
Apr 09, 2012 | Lenovo 3000 N100 Notebook
I need CDRKING USB LAN TM-1029 driver.. i cant install it.. the cdrom with the device doesn't work.
You can download the driver on this link:
http://files.cdrking.com/downloads/usblan.zip
If I could be of further assistance, let meknow. If this helps or solves the issue, please rate it and give a testimonialfor my response.
Aug 06, 2011 | Computers & Internet
How can i block my router TM-G5240 to other computers?? tks
one word "permissions"
you have to tell the router and the firewall that you don't want "abc" user to use the router.
this is done by logging into the router and allow/disallowing the user by MAC address ( Media Access Control) .
depending on the router to access it is going to a browser window and entering either 192.168.0.1 or
192.168.1.1
instruction set to secure your router is in the "helps" file.for
1.select the "Advance tab
2. select filter "MAC'
3. Enter name
4. under MAC address enter MAC address
5.on the DHCP Client select DHCP client from the pull down list; click Clone to copy that MAC address
Jul 23, 2011 | D-Link Tmobile Hotspot Tmg5240 Wireless...
Windows 7 password reset bought at a auction dont know main password
Download the Ophcrack Live CD: http://pcsupport.about.com/gi/o.htm?zi=1/XJ&zTi=1&sdn=pcsupport&cdn=compute&tm=48&gps=88_10_1152_572&f=10&su=p284.9.336.ip_p504.1.336.ip_&tt=4&bt=1&bts=0&zu=http%3A//ophcrack.sourceforge.net/ and burn it to a disk using Image Burn: http://www.imgburn.com/index.php?act=download
Then just boot the computer with the Live CD in the CD/DVD drive. If it doesn't boot into the CD you will have to go into the BIOS and set the boot order so that the CD/DVD drive boots first. Most computers will tell you which "F" key to press to get into "setup," also called the BIOS. Sometimes it is the "del" key.
Be advised that it is a criminal offense to break into a computer that doesn't belong to you.
Jul 16, 2011 | E-Machines eMachines Desktop PC
I bought a D-link TM-g5240 . The wizard setup doesnt work. error:Your ethernet connection could not be verified. It says disanle firewal. I did disable everything, antivirus and firewal. Same...
Are you trying to connect to this router wirelessly or with an ethernet cable? If you are already using an ethernet cable, try using a different cable in case the first cable is damaged.
May 05, 2011 | Computers & Internet
I have a TM-T88IIIP model MI29C and windows 7 operating system. Do you have a download available for this?? Thank you Carol
Here's the driver link for the Epson TM-T88IIP Receipt Printer: http://www.posmicro.com/RECPRINTERS/EPSON/Epson-TM-T88II.htm
This link will take you to the download page for the manual as well. This driver is supposed to be for Windows XP but should work for Windows 7 32 bit OS. Give it a try - if it doesn't work or won't install, then post back to this solution and I will help you further. It is likely that a Windows 7 driver doesn't exist, but unless you have the 64 bit version of Windows 7 this driver should work one way or another.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
May 03, 2011 | Computers & Internet
I had formatted my system so i want to install audio driver so help me
When you had bought the motherboard, processors and other accessories from your retailer (for an assembled PC), or bought a trademarked PC or Laptop, they had certainly given you a CD containing DRIVERS compatible for your system which includes drivers for AUDIO, VIDEO, GRAPHICS CARD, WEBCAM, and others depending your system configuration. Now, just find out the CD and install those drivers included in it and you are done! By the way, if you have WINDOWS Vista^TM or Se7en^TM installed, you don't need such type of audio drivers at all! These OS have in-built audio and video drivers in it.
Dec 12, 2010 | Computers & Internet
D link security
refer to page 12 and continue on through the user manual for the steps on how to login and secure the router. It is a very straightforward process. Here is the link to the manual:
http://docs.bgmicro.com/pdf/tm-g5240.pdf
Thank you,
Lee
Aug 25, 2010 | D-Link AirPlus DI-524 Wireless Router
Cell Phones Logo
49 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
